I am not staying stock, but I went with 5.29 as well as a front locker. Couldn't be happier. I was warned about the RPMS getting too high since I don't have 33s for tires. But so far it hasn't been bad at all!I'm considering changing out my stock differential on a 2017 4x4 TRD-OR.
Is there anyone who has made the gear change but kept the truck mostly stock? Pros and cons?
Did anyone add a front locker as a part of the change?
Honestly I haven't noticed too much issue with it, but then there aren't many hills around here. I'll be putting it through its paces fI run my truck (6AT) on 4th gear on the highway quite a bit. When I did the math, it's comparable to 6th gear (with 5.29) and I'm happy with the RPM / power tradeoff.
I'm still not happy with the gear searching it does on modest hills. How is that working for you using 5.29 @Icefog34?
I probably wouldn’t run more that 5-600 lbs.@UploadAdventure. By "bunch of weight", how much? 200lbs, 500lbs, 1000lbs?
You're making me feel better about my decision to go with 5.29's. I added the bed rails, will be going with a RTT, as well as a new high clearance rear bumper with swing arms.I probably wouldn’t run more that 5-600 lbs.
Pretty if you get full armor and stay under 33 you’d be good. Now this doesn’t include a roof rack. Bed rack. RTT. If you’re going to be adding all that then you might want to think about them 5.29’s.
You hit them 35’s and you might not see an issue 4.88’s, but it’ll be shifting a lot more.
Right now I hold 6th pretty much all the time. I drive 35 miles each way for work. 6th at 70 is about 2400 rpm. I’m on 285/70/17 (32.7) if I go up in tire size to 285/75/17 my rpm will drop to like 2200. Etc etc. But I’m rarely if ever in 4th. Where as before I couldn’t even see 6th on the stock gears.
I’ll tell you this.You're making me feel better about my decision to go with 5.29's. I added the bed rails, will be going with a RTT, as well as a new high clearance rear bumper with swing arms.
I believe it. I figured if I was going to spend the money to do it, why waste it on the smaller gear that may or may not make much difference. Go big! lolI’ll tell you this.
I’ve NEVER heard anyone complain about 5.29’s. But I have heard people wish they had done them over 4.88’s...
Exactly. Why have to do it twice. I know several guys who have done it twice...I believe it. I figured if I was going to spend the money to do it, why waste it on the smaller gear that may or may not make much difference. Go big! lol
6th gear on my truck. At 70. On 285/70/17 (32.7) I sit at 2400 or so.The stock 3g seems to play well in the 2000-3500 rpm range, which is also why I seem to like 4th gear the most. If 6th gear with 5.29 does that, I think I'm sold.
If you don’t go any higher than 33’s 4.88’s should be fine.I'm going to Re Gear this Saturday..still undecided on 4.88 or 5.29...I'm running 33's , rock Sliders, Prinsu Rack Skid plate...Daily driver hit local trails nothing to crazy..Which ones should I get?
I often run my truck on 4th on the highway. Given the gear math, I think it gives an idea what it might be like (I may be way off on this) I run mostly stock (32 inch tires) with a GFC on the bed full time. Once this virus stuff clears up, I'm going to find an installer and get it done to 5.29.I'm going to Re Gear this Saturday..still undecided on 4.88 or 5.29...I'm running 33's , rock Sliders, Prinsu Rack Skid plate...Daily driver hit local trails nothing to crazy..Which ones should I get?
5.29’s are awesome.
Here’s the deal though.
If you’re going to stay on 33’s or lower and not add a bunch of weight. Go with 4.88’s. That’ll be perfect for highway driving and such.
and as far as the locker. You or a shop is already in there. Might as well do it. Otherwise it’s +6 hours labor and a gear reset up. Might as well as just do it one and done.
I'll add my experience after this little note. Everyone is going to experience gears differently. This is why you see people preaching 4.88s on flat ground. Where as someone who lives in a hilly area or at elevation, would preach 5.29s. You also need to take into account of which transmission you have. If you have an automatic, 5.29s are the way, if manual, you need to really think about whether you need 5.29s.
Everyone will also have different driving habits, someone might drive "like a grandpa" and 4.88s would probably be more than enough. I see a lot of people say their trucks perform just fine with stock gears on 33's. These people probably either don't drive highway speeds frequently, or they live in a mostly flat area. Then there are people like me. I would sell the truck before being forced to stay with stock gears on 33's
Now. With all that being said, I have 5.29's in mine on stock tires with the automatic trans. Granted, I intend on fitting a tire around 33"-35". I also intend on a steel rear bumper, aluminum front, full skids, and a RTT on a bed rack (or canopy, still undecided).
I live on a very hilly island, and hit roughly 50mph each way to and from work, uphill and back down, most of the way. I legitimately can't think of one road on my island that isn't at least a 2% grade for the majority of it. With that, for me, they work great compared to the 3.91s. I'd even go as far as saying I wish I could have more. I'm certain that when I get the tires on, my next upgrade will be OV tune.
But that's just with my driving habits in my area. It could be different for you.
Not a dumb question!Dumb question time: why add a locker to the front? is that primarily for crawling over bolders and such?
Thanks, thats helpful. So question for you: what are your thoughts on which gear I should get?
Here is what I have: TRD OR with approximately 3.5" lift on 295/70R17 Nitto Ridge Grapplers. I have an aluminum front bumper and steel rear bumper. Steel sliders and Prinsu Roof Rack. I do not have RTT or rack (never plan to). I don't tow anything (maybe will rent a tear drop some day). I don't bolder crawl (its not a Jeep). My MPG is 13 and it hunts for gears, and is slow as a dog. I want to regear to improve MPG and provide a smoother drive in city/hwy. Future plans are to MAYBE add a winch and replace the rear bumper with a CBI swing out to hang my tire back there.
What gear ratio should I go with?
Are the higher ratios considered to be much weaker because of smaller teeth on the gears?
Is switching a MT to 5.29 about the same as a AT to 4.88
I only know of one person with 5.29 in an MT and that’s because they added a FWC. MT trucks either stay stock or go 4.88.Are the higher ratios considered to be much weaker because of smaller teeth on the gears?
