2016+ Tacoma Hidden Winch Mount
SDHQ OFFROAD
sdhqoffroad.com
SDHQ presents an easy way to mount a winch on your 2016+ Tacoma while maintaining the stock front bumper. Slight modification and trimming to the stock bumper plastic is required to allow access to the winch line and fairlead. Our winch mount is CAD designed for precise fit and is constructed out of 1/4" thick mild steel. Precision bent and mig welded for strength and durability. After initial construction, the winch mount is powder coated matte black for a nice, long lasting finish that will withstand anything you can throw at it!
The SDHQ winch mount has been designed to fit the Warn Zeon 10 Platinum series of winches with wireless controller. Other winches that are similar in size with the same bolt pattern may fit but are in no way guaranteed to fit by SDHQ or its distributors. We at SDHQ recommend the Zeon Platinum series winches because they have a wireless controller which allows full functionality of the winch. Winches with a manual clutch will not have the ability to "free-spool" unless a device is built to access the winch's clutch release.
Relocating the winch control box on the Zeon series is necessary due to clearance issues. We have optional kit that includes all the wiring and hardware needed to relocate the Zeon series control box. Relocating the control box is possible without our kit; however, the end user will need to source their own wires and hardware.
Key Features
  • No Drilling Required
  • Bolts Directly into frame and adds support to Bumper/Frame Horns
  • ¼” Thick Steel Plate Construction for Durability
  • Designed specifically for the Warn Zeon 10-S Platinum with Wireless Control
  • Optional Control Box Relocation Kit
  • Integrated D-Ring Mounts
https://sdhqoffroad.com/collections...t-toyota-tacoma-sdhq-built-hidden-winch-mount
