- T3G Member
- #15
- 821
- 1,437
- @PROTACO17
Hey everyone,
Since ive picked up a fridge, i will be adding a 12V outlet with a rocker switch so that i can power the fridge rather than using the 110 inverter that is supplied in the truck bed of my tacoma. I will update this thread when i start the install and get everything wired, my BIG question is, what size fuse should i run from the battery positive to the outlet. The max amp load for the fridge is 7.8, but i bought a 12v outlet with some USB ports as well for charging phones and stuff. Would a 25amp fuse be overkill or could i get away with say a 10-15amp fuse for this application? Im not well versed in electronics as i wish i was so i figured id turn here for some advice!
