0uTkAsT's 3-Pedal Rebel | Build & BS
0uTkAsT
9️⃣ Legend
IG: @low_speed_high_drag
2018 TRD Off-Road 4x4 Manual with no Tech or Premium purchased new 5/11/18, replaced a 2016 Tacoma SR V6 4x4 Automatic.
img_20180810_164258-1173x1173-jpg.5614
Current Mods
Suspension
ADS Custom Length 2.5" Remote Reservoir Coilovers
ADS Custom Length 2.5" Piggyback Reservoir Shocks
Eibach 14" x 700lb Springs
SPC Gen 3 Forged Upper Control Arms
OME Dakar Heavy Leaf Packs
OME Carrier Bearing Drop Kit
Energy Suspension Polyurethane Bushings & Sleeves
Headstrong U-Bolts
Wheels, Tires & Brakes
17x9" Vision Nemesis 111s w/ Nylon Rock Rings
Gorilla Black Spline ET Lug Nuts
No-Loss Valve Stem Caps
285/75R17 Falken Wildpeak AT3W
Crown Performance SS/Kevlar 1"/4" Extended Brake Lines
SDHQ ABS Shield
Protection
DV8 Rear Bumper
RCI Powder Coated Steel Skid Plate
Avid Off Road 20-Degree Bolt-to-Frame Sliders
Avid Off Road Cab Mount Chop & Pinch Weld Mod
Diff Breather Relocation
High Clearance Exhaust
Lighting
Rear Flush Mount Pods
TRD Pro Tail Lights
SEALIGHT LED Reverse Bulbs
Utility & Recovery
Custom Avid Off Road 3-Bar Bed Rack System
WaterPORT Day Tank Pressurized Onboard Water System
2nd Gen Front Bed Rail
QuickFist Clamps
Mounted Extinguisher
Mounted Axe
Mounted Shovel
Mounted Race Jack w/ Lift Pad Extensions
Motormic Shackles w/ Isolators & Sleeves
Snatch Strap & Bridle Strap
Onboard First Aid Kit
Onboard Tool Kit
Onboard Oh Shit Kit
Desert Rat Air Down Gauge
ARB Patch Kit
HF150 12v Compressor
Miscellaneous
Freespirit High Country Series RTT w/ Annex
AIRAID Cold Air Intake
T-SB-0058-18 ECU Reflash
30% Tint
AVS In-Channel Vent Shades
Debaged
Salex Center Console Organizer
Modified Glove Box Organizer
Modified WeatherTech Floor Liners
Memory Foam Dog Seat Platform
Black Tailgate Letter Inserts
Carista Seatbelt Chime Delete
Planned Mods
Full Size Spare
RCI Powder Coated Steel Transmission Skid
Baja Designs Squadron Pro Amber Driving Combo FPK
Dometic CFX 40W Fridge
ECGS 5.29 Regear w/ Sintered CV Bushing
Plastics Guy Bump Stops & U-Bolt Flip Kit
Focal IC 690TOY 6x9" Door Speakers
Kicker Tweeter Upgrade
High Clearance Y-Pipe Reroute & Heat Shield
Rago Fabrication Group 31 Battery Cage
X2 Power Group 31 AGM Battery
URD Stage 3 Clutch
Black Headlight Mod
7r41lbr34k3r Delrin SS Hybrid Shift Knob & Seat Risers
Total Chaos Rear Channel Bed Stiffeners
TRD Mod Front Camera Kit
Energy Suspension Polyurethane Body Mount Bushings
This was my previous 3rd Gen... affectionately known by all as the Rock Flinging ExpoTurd. This was an early-production '16 SR V6 4X4 ordered it 09/15 with only two factory options and zero port or dealer add-ons - about as basic as a V6 3rd Gen gets. I took delivery on 11/4/15 and traded it after 2 years, 6 months, 8 days, 1 front diff, 1 transfer case, 2 sets of door seals, 2 window guides, 2 bubba lips, 1 driver's seat, 1 headunit, (probably more that I'm forgetting) and 36,000 miles. It was traded with most of the modifications still installed. We loved it but it was truly a piece of shit... built on Day of The Dead in Mexico so I guess that explains it.
26907997_10154816572615904_7063161420950_12b65f07309dc9dd9ad9d9a1daea602c645daa44.webp
27331629_10154818959270904_2475061076593_77c13a63d5086ca1fb039a8d030ed4ca4006d6fa.webp
ExpoTurd's Mod List:
Wheels, Tires & Suspension
- OME 888 Coils
- 2nd Gen Bilstein 5100 Front Shocks
- Headstrong 1/4" Top Plate Spacer
- Headstrong Poly Bushing Kit
- Sway Bar Delete
- Light Racing Gen 2 Upper Control Arms
- Dakar Heavy Duty Leaf Packs
- Headstrong Center Pin Lengthener Kit
- Headstrong Billet Degree Shims
- Zip Tie / Lithium Grease Mod
- Bilstein/RCD B110 Rear Shocks
- OME Carrier Bearing Drop Kit
- Headstrong Extended Kevlar Reinforced Stainless Steel Rear Brake Lines
- Rear Brake Line Bracket Relocation
- Extended ABS Sensor Cable Bracket
- 17x8.5" SCS RAY10s w/ Black Spline Lugs
- No-Loss Valve Stem Caps
- Falken Wildpeak AT3W 285/70R17
- Full Size Spare on OEM 17" Steel Wheel
Armor & Recovery
- Avid Off Road Welded Sliders
- Avid Off Road Custom 8.5" 3-Bar Bed Rack w/ RTT & Quick Fist Tabs
- Avid Off Road Cab Mount Chop
- RCI Powder Coated 3/16" Steel Skid Plate
- Modified Harbor Freight Racing Jack w/ Aluminum Skid
- Pro Eagle Lift Pad & 13" Extension Kit
- Quick Fist Bed Mounts
- Kiddie Extinguisher in Quick Fist Nozzle Clamp
- Modified Harbor Freight Spade Shovel & 3-1/3lb Trail Axe in Quick Fist Clamps
Cosmetic & Miscellaneous
- Geo Adventure Gear Gray GT-165A Roof Top Tent w/ Annex
- Rightline Gear Rooftop Cargo Carrier
- AFE Stage 2 Cold Air Intake
- MBRP High-Clearance Exhaust
- No-Drill Diff Breather Mod
- Lucas Oil Extra Heavy Duty Joint & Bearing Grease
- Shift Enhancement TSB
- WeatherTech DigitalFit Floor Liners
- ASWF Excel IRP Tint, 32% Sides/Rear & 50% Full Windshield
- 2nd Gen Front Bed Rail
- DIY T-Slot D-Ring Tie Down Points
- 120W Inverter
- Tailgate Letter Inserts
- Custom @CBoy808 Window Vinyls
- Plasti-Dipped Badges
- TRD Aluminum License Plate Frame
- TRD Leather Shift Knob
- Salex Center Console Organizer & 3M Key Hook
- Costco Memory Foam Dog Bed for Rear Seat
- AVS VentShade In-Channel Window Visors
Lighting
- Rago Fab Ditch Light Brackets w/ Cali Raised 18W LED Pods, Air On Board Switch, and Amber Rigid Dually Covers
- Apex Fabworks LED Pod Fog Light Retrofit w/ Amber 18W Cali Raised Pods & Air On Board Switch
- JDM ASTAR LED Reverse Bulbs
28379365_10154898354500904_7724849047415_edc529d6706c39376eb572702eed5e3f6a92433b.webp
26961570_10154820439565904_3533108103454_8fcbbf740e520f8ee64fee035b4d71772cc9d183.webp
No bypasses? No interest
GO BACK TO TACOMAWORLD, DICK
:whistle:
Did you get a new RTT? Thought you were looking at a 23zero
No new RTT yet. Two times I was told that I could get a deal on either the 23zero or the FSR, but both times I was let down. I can go pick up the 23zero any day of the week for full MSRP plus sales tax at Turtleback Trailers in Phoenix but we are not in a hurry and I'm kind of hoping for a sale of some sort to come along before camping season starts again.
Welcome to T3G, glad to see you’ve decided to indulge in our 3rd gen community. Nice build and well written posts around the forum so far!
Keep spreading the word if you guys have more friends that you think would love this place. ;)
Absolutely will man! love to see this place take off. Good chance to start fresh and fill it with good tech knowledge and and appropriate amount of ball busting..
We gotta step up your game. Let's plastidip your shocks and use metalizer for that added special touch.... and we know how you like special touches
You always make me feel special with your touches :love:
And hoooo-wee that's a great idea, I'mma go buy me some red Plasti Dip so everyone will think I have some of them there super custom Rancho Shocks like all the Ferd F-Teenthousands rolling coal in the QC
