Will a 2.5 inch lift with zero-offset wheels with 33’s cause rubbing without trimming?
Trucker2000
I’ve been reading conflicting views on whether I will get rubbing with 33 inch tires. I have a 21 tacoma short bed and would prefer not to do any trimming. Will a 2.5 lift with bilstein 5100 give me the required clearance. Ideally I would go -10 offset on wheels but understand I’m likely to get rubbing with this configuration.
I am looking at fitting wildpeak At3 tires.
I have 33 BFGs (285 width) with zero offset rims (17 inch) on 3 inch rear and 1.5 front and I had to do a trim and some heating and reshaping.
Stay stock wheels and you'll rub a bit in your control arms (like I do) but nowhere else. Get wider or offset rims and you'll rub a bit on the bumper or body/fenders just behind the front wheels. Get skinny tires and you'll avoid rubbing anywhere.
I have 33 10.5 on zero offset with a 2 inch lift and there was some plastic rubbing. Not a lot. Minor trimming.
-M
would downsizing to 32s with offset work without rubbing?
What’s the offset of the ‘20 pro wheel? +4mm?
Curious if I should remove my wheel spacers before I put larger tires on. The sport wheel is +30 so with spacers I’m at -1.75. Seems like negligible amount but rather prepare to fight the red locktite ahead of time if I do need to pull them.
Yes, if you go bigger, the wheel spacers will cause you to rub on your cab mount and fender edges in the *front.*
The rear will be fine. I've got wheel spaces on mine, and they work great. Kept them off in the front.
Ok great to know, thank you. I tried to guesstimate the scrub of the tire by watching the current setup, but adding an inch and a half to each side is definitely cutting it close. I’ll pull the spacers next week for sure.
