    This website is the hobby-project of a USMC veteran/mechanic, @Tyler. I created Tacoma3G.com to share my knowledge of this subject with others and to provide like-minded folks with a comfortable space to ask questions and create 'build threads' within our Tacoma Forums.
    Now, if the format of this website is confusing to navigate for you, or if you're interested in my full mission and T3G's history, check out the Help and About pages.
Where do the wires run???
Blackhawk96dr
Northern Utah
2018 Sport DCSB Auto
Quicksand
I'm getting a PRINSU CabRack for my 2018 Taco I want to do a 40" light bar in front on the rack and a 10" light on each side and one facing back. My question is where do I run the wires for the switches and the power with out having wires running 30 feet from the top down the back then back to the fire wall and the battery or drilling a hole in the roof (not an option) any ideas or experience having done this.
Run the wires down each side of the windshield there is a tight channel between the black molding and the A-piller you can tuck wires on each side each side will hold about 1 8awg aize if wire so no problem for what you want to run x do it with lube and caution
The above answers are solid, I'll also add that inside the engine compartment, on the firewall, on both driver and passenger sides there are large round rubber grommets. These are the access that some of your wiring is already taking advantage of in going from the engine compartment to the passenger compartment. You can push wiring through these to get inside the cab.
If possible use passengrr
That’s exactly how friends have done it and they say it’s fine there rarely the wire will pucker out but just with finger pressure u pop it back in
One of the cleanest places for shure, unless you mod the shark fin antenna
