yesShould i upgrade CV axles with a front locker?
Thanks. I never thought about thatJust to add my 2¢.
My truck is a 2017 with Nitro Gear 5.29s. It still has stock CVs. Over the years, I have abused the truck in all the possible ways off roading. Like, I hardly make an attempt to be smart and avoid damage. I’ve had 35s, 35s with no sway bar, and now 37s. My truck is about 7,800 lbs, with 37s on it, driving all over the country, off roading in places like Moab etc. I have broken most other things under the truck but still not the stock CVs.
I kind of think of it like this: If you let the CV axle be your weak point, you probably won’t break those expensive Nitro Gears because the CV will snap first. But if you beef up the CVs (and the aftermarket options are beeeefy), the weak point probably shifts to the gears inside the diff and you know what that means.
