    This website is the hobby-project of a USMC veteran/mechanic, @Tyler. I created Tacoma3G.com to share my knowledge of this subject with others and to provide like-minded folks with a comfortable space to ask questions and create 'build threads' within our Tacoma Forums.
    Now, if the format of this website is confusing to navigate for you, or if you're interested in my full mission and T3G's history, check out the Help and About pages.
TSS
Tylewis25
I have a 2018 6 in pro comp lift on 35s and I did a U turn the other day and my pre collision system malfunction light came on my dash and I talked to corporate to see if it can be adjusted to fit my lift and they said yes but no dealership in my area (Jax,FL) will do it any suggestions on how to drop it lower?
I pulled up 3 dealers in the city of Jacksonville. if you are stations at NAS Jax Keith Pierson Toyota is probably closest
did you try the other dealers? otherwise id pull the neg battery cable and see if that made it go away
I called all 4 said they won’t do it because of my lift, it also won’t let me engage 4 wheel drive you think pulling the cable will let me use 4 wheel drive??
