Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to Tacoma3G.com, a free resource for 2016-2023 Toyota Tacoma owners!
I am going on a trip shortly and will be towing a trailer.
I was wondering if anyone has a recommendation for a ODBII transmission temperature gauge.
Also; what is the temperature that I should become concerned at?
I use the OBDFusion app on my phone and a Bluetooth module I got from Amazon. Temps usually hover around 190. When the truck is really working and it's hot it'll hit 210. That's the highest I've seen and the factory gauge on the dash is still dead center at that point. I'd be concerned if it started skyrocketing above that.
Thanks for the information. I ended up getting a Scangauge II since it was quick and easy to set up, albeit a pricier solution. There were some good reviews and setup guidance on some of the other forums as well. I like your solution too, I just waited a little too long.
I ended up running around 190 +/- 5 the whole trip down the highways and even in the mountains towing a 3500 lb. trailer and load.
I kept it in S4 and used the ECT and it cruised along nicely at about 2900-3000 RPM running around 67 MPH.
