Wheels / Tires TOYOTA TACOMA TIRES: PROS AND CONS OF GOING 35'S, 37'S, AND BEYOND
TacoClout
Website
www.tacoclout.com
2020 SR5 DCSB Auto
Midnight Black
Article originally posted: https://tacoclout.com/ultimate-guide-to-fitting-larger-tires-toyota-tacoma
When it comes to enhancing the performance and aesthetics of your Toyota Tacoma, one of the most popular modifications is upgrading the tires. Whether you're an off-road enthusiast seeking adventure on challenging terrains or a daily driver navigating city streets, choosing the right tire size can significantly impact your Tacoma's overall performance. In this guide, we'll delve into the pros and cons of opting for larger tires, catering to the diverse needs of our core customers – the passionate Tacoma owners.
PROS:​
  1. Improved Ground Clearance:
    • Off-road enthusiasts will appreciate the increased ground clearance that larger tires provide. This enhancement allows for better traversal over rocks, mud, and uneven terrain, reducing the risk of undercarriage damage.
  2. Enhanced Traction:
    • Larger tires often come with deeper treads, providing better traction in off-road situations. This is particularly beneficial when conquering challenging trails, muddy paths, or sandy surfaces.
  3. Aesthetic Appeal:
    • Upgrading to larger tires can give your Toyota Tacoma a more aggressive and rugged appearance. This is a popular choice among enthusiasts who want to personalize their vehicles and make a statement on and off the road.
  4. Increased Load-Carrying Capacity:
    • For those who use their Tacoma for hauling or towing, larger tires can offer improved load-carrying capacity. This is especially relevant for Tundra owners looking to maximize their truck's utility.
  5. Enhanced Stability:
    • Larger tires can contribute to increased stability, particularly when cornering or navigating rough terrains. This can enhance the overall driving experience, providing a sense of control and confidence.
CONS:​
  1. Fuel Efficiency Impact:
    • One of the trade-offs of larger tires is the potential decrease in fuel efficiency. The added weight and increased rolling resistance can lead to higher fuel consumption, affecting both off-road adventurers and daily commuters.
  2. Speedometer Inaccuracy:
    • Switching to larger tires can impact the accuracy of your speedometer, as it's calibrated for the original tire size. This discrepancy can lead to potential legal issues and affect the precision of your vehicle's onboard systems.
  3. Braking Performance:
    • Larger tires may require a longer braking distance due to the increased rotational mass. This can be a critical factor in emergency situations, both on and off-road.
  4. Fender Clearance and Rubbing:
    • Installing larger tires may lead to clearance issues, especially if your Tacoma isn't equipped with the necessary lift kit or modifications. This can result in tire rubbing against fenders, causing damage and limiting the tire size options.
  5. Cost Considerations:
    • Upgrading to larger tires involves not only the cost of the tires themselves but also potential modifications like lift kits and re-calibration of the speedometer. Customers should be prepared for the additional expenses associated with this modification.
WHAT SIZE TIRES WILL FIT?​
We have put together a general guideline for you and what size lift you may need to run these sizes. The listed lift sizes are approximate and may need adjustments based on the specific setup. Always consult with a professional or do thorough research before making modifications to ensure compatibility and safety.
  1. Stock Tire Sizes:
    • 265/70R16 (approx. 31.6"x10.4") - Stock suspension
    • 265/65R17 (approx. 30.6"x10.4") - Stock suspension
    • 265/60R18 (approx. 30.5"x10.4") - Stock suspension
    • 245/75R16 (for base models) (approx. 30.5"x9.6") - Stock suspension
  2. Mildly Larger Sizes (may require minimal modifications):
    • 275/70R17 (approx. 32.2"x10.8") - Stock to 2-inch lift
    • 275/65R18 (approx. 32.1"x10.8") - Stock to 2-inch lift
    • 285/70R17 (approx. 33.7"x11.2") - 2 to 3-inch lift
    • 265/75R16 (approx. 31.6"x10.4") - Stock to 2-inch lift
  3. Larger Sizes with Suspension Lift (may require significant modifications)
    • 33x12.5R17 (approx. 33"x12.5") - 3 to 4-inch lift
    • 285/75R16 (approx. 33.8"x11.2") - 3 to 4-inch lift
    • 305/70R17 (approx. 33.8"x12.0") - 3 to 4-inch lift
    • 285/65R18 (approx. 32.6"x11.2") - 2.5 to 3.5-inch lift
  4. Off-road and Larger Sizes (WILL require significant modifications):
    • 35x12.5R17 (approx. 35"x12.5") - 4 to 6-inch lift
    • 35x12.5R18 (approx. 35"x12.5") - 4 to 6-inch lift
    • 295/70R17 (approx. 33.3"x11.6") - 3 to 4.5-inch lift
    • 315/70R17 (approx. 34.4"x12.4") - 4 to 6-inch lift
Remember, these are general guidelines, and it's crucial to consult with a professional or refer to the specific recommendations of your chosen tire and suspension manufacturers for the most accurate information based on your individual setup and preferences.
Conclusion:
Choosing the right tire size for your Toyota Tacoma involves a careful consideration of the pros and cons, weighing the needs of off-road enthusiasts and daily drivers alike. While larger tires can enhance off-road capabilities and visual appeal, it's essential to be aware of potential drawbacks such as fuel efficiency impacts and braking performance. As a dedicated provider of aftermarket parts and accessories, we understand the diverse needs of Tacoma owners and aim to equip them with the knowledge needed to make informed decisions about their vehicles. Explore our range of Toyota Tacoma tires, keeping in mind the unique demands of your driving experience.
