Talk me out of these spacers
RevN3
7️⃣ Connoisseur
Rig of the Month (2x)
So I was plugging around on Amazon for interesting parts and I stumbled on these:
They are crazy cheap which I wonder if that is reason alone to hesitate. I'm all stock though and I like the idea of a wider stance if only for the looks...but I don't really know the pros and cons of spacers. I searched around the forums but I couldn't really find a breakdown. Anyone want to school me or point me to a source?
Avoid bargain spacers at all cost.
It’s cheaper in the long run.
I got some from Marlin Crawler (g2), thinking they would be good. Had to grind down studs to work with my wheels and then turned around and took them off the next evening. Not going to risk it at all.
Planning on new wheels to make up for the spacer look I wanted.
Cons - are " creating a greater leverage point" on your hub it may or may not create extra wear on components
Cons - may have tire rub (your stock so not really an issue)
Cons - if your studs are long and improper rims you may have to replace studs or grind them like @Jfrisch01
Cons - cheapos may or may not be inferior grade of metal for the task
Cons- cheapos have cheap powdercoating
Pros - make the truck look great
