Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to Tacoma3G.com, a free resource for 2016-2023 Toyota Tacoma owners!
I have a 97 taco i can fit 33s no problem. I’m trying to upgrade to 37s, currently on the truck i have a 3’’body lift and a 2.5 leveling kit also i run 2 inch wheel spacers
will i have to do any major trimming?
A quick search shows that the maximum you should go on a 6" lift is 35's for clearance.
For 37's, you'll need 6" lift + 3" body lift. Even then you might need to trim.
Even less lift and you're gonna get into heavy modifications. Might as well grab the sawzall, grinder and plasma cutter. Source: https://www.youtube.com/watch?v=dFI-BpehAOw
Without going that high, you'll just be doing a lot of 38 point turns.
