Suspension Taco lean spacer install and front coilover install
Tyler
🔟 Mythical
Badministrator
I ended up having to pull the coilover to fix my Taco lean so this video shows what to do for both.
The coilovers were already assembled
I'm gonna have to do this again soon. Not looking forward to it though.
Tyler
🔟 Mythical
Badministrator
So you do not need to worry about the position of the alignment cams if you are going to get an alignment anyway?
You do. Use a paint pen or sharpie to mark where they were at before you break the torque. When you go to put it back, line up your lines, but expect it to still be off until you get to the shop.
DesertYota18
Hey Rob quick question...After installing the spacer, do you have any chatter coming from the driver side (side with spacer) while off-roading? Just curious, because I installed the spacer to correct driver side lean and torqued everything to spec, however when off-road I hear what sounds like metal to metal contact.
Rob Daman
7️⃣ Connoisseur
No noise. Look around for any rubbing.
