Trying to get some feedback/thoughts/opinions/observations from the hivemind.
Many have gone down the trail of lifts and such. I'm a fan of buy once, cry once.
I would ideally get 2 inches of lift in the front and the rear.
I don't mind the stock rake so up in the front and rear at the same is what I'm aiming for.
I'm not in baja, nor doing big air. I don't see the need for long travel.
Having my tires on the ground, traction and comfort is the keys in the use cases.
Here are my use cases:
Able to drive from Minnesota to Arizona on highway/2 lane blacktop.
Washboard road driving without feeling like the truck will rattle apart. (this was our experience at Sheep Mountain Table and other gravel roads in Wyoming/Montana/South Dakota and Minnesota).
Drive from Minnesota to Utah then run something like fins and things.
What I'm kicking around:
What I'm fairly certain on:
UCA: Ball Joint Upper Control Arms | DK-811901
Rear: Deaver/Dobinsons leaf pack.
If I'm running around town, I'd be running the armor and tonneau cover.
If I'm long hauling to a location, I might be carring bikes and gear.
Now for the undecided:
Shocks/Coils:
Front: I'm thinking based on my use cases, on the side of the road adjustability is going to be ideal.
650 lb coils.
King OEM Performance Series 2.5" Coilover w/ Reservoir and Optional Compression Adjusters - 05+ Tacoma
Rear: Same with the front, adjustability.
King OEM Performance Series Rear Shock Kit with Optional Compression Adjusters (PAIR) - 05+ Tacoma 25001-121/25001-121A
Tires:
Looking to run about a 32" tire, nothing bigger as I don't want to go down the road of cutting too much as of right now.
Weight over stock:
Front bumper and winch estimating ~150 lbs (to be ordered).
Rock sliders: ~ 200 lbs.
Diamondback cover ~ 100 lbs.
Skids:
Gas tank skid ~ 25 lbs.
Gear:
Usually around 200, depending on camping, backpacking, cycling, etc.
Shocks/Coils:
650 lb coils.
Tires:
Weight over stock:
Skids:
Gear:
