Stock TRD 2023 Sport rims
Just because they fit does not mean they will not rub when articulated.
Lot of people put bigger tires on trucks,.. some install lifts and some just fit what they can stuff in there,...... even if lifted,... just stuff it.
Make sure all components are strong enough and torqued properly.
Most tire shops will be glad to "fit" a tire on (front) wheel then lower it to get vehicle weight and turn the wheel to see if it rubs.
They want to sell the tires,....... you want to make sure they work.
There is no warranty on "looks good from my house"
Source: https://youtu.be/v4qfWknMJMA
Pretty sure the TRD +mm offsets are:
25mm = 1"
7 1/2" wide Sport Rims +30mm
7" Off Road +25mm
7" Pro +10 some are years reported as +13mm
7" 4Runner +4mm
Tire sizes vary by manufacture:
265/65/17 TOYO is wider than a 265/65/17 Goodyear
Not by much but it can make the difference.
Note a larger tire WILL add weight that WILL be noticed on acceleration / braking and inertia.
Just because they fit does not mean they will not rub when articulated. Lot of people put bigger tires on trucks,.. some install lifts and some just fit what they can stuff in there,...... even if lifted,... just stuff it. Make sure all components are strong enough and torqued properly. Most tire shops will be glad to "fit" a tire on (front) wheel then lower it to get vehicle weight and turn the wheel to see if it rubs. They want to sell the tires,....... you want to make sure they work. There is no warranty on "looks good from my house" Source: https://youtu.be/v4qfWknMJMA
Wow
Anyone running 275/75/R17 on stock 2023 4x4 Sport rims with a 2 1/2 lift do tires clear uca without spacers
Based on the offset alone of the Sport OEM wheel, you will likely rub consistently on a 275 tire mounted. Usually we'll see people kiss the top of their UCA with the inner sidewall of the tire on a spec like that.
