Stock TRD 2023 Sport rims
Just because they fit does not mean they will not rub when articulated.
Lot of people put bigger tires on trucks,.. some install lifts and some just fit what they can stuff in there,...... even if lifted,... just stuff it.
Make sure all components are strong enough and torqued properly.
Most tire shops will be glad to "fit" a tire on (front) wheel then lower it to get vehicle weight and turn the wheel to see if it rubs.
They want to sell the tires,....... you want to make sure they work.
There is no warranty on "looks good from my house"
Source: https://youtu.be/v4qfWknMJMA
Pretty sure the TRD +mm offsets are:
25mm = 1"
7 1/2" wide Sport Rims +30mm
7" Off Road +25mm
7" Pro +10 some are years reported as +13mm
7" 4Runner +4mm
Tire sizes vary by manufacture:
265/65/17 TOYO is wider than a 265/65/17 Goodyear
Not by much but it can make the difference.
Note a larger tire WILL add weight that WILL be noticed on acceleration / braking and inertia.
Just because they fit does not mean they will not rub when articulated. Lot of people put bigger tires on trucks,.. some install lifts and some just fit what they can stuff in there,...... even if lifted,... just stuff it. Make sure all components are strong enough and torqued properly. Most tire shops will be glad to "fit" a tire on (front) wheel then lower it to get vehicle weight and turn the wheel to see if it rubs. They want to sell the tires,....... you want to make sure they work. There is no warranty on "looks good from my house"
Running 275/75/R17 tires on the stock 2023 4x4 Sport rims with a 2.5" lift may work, but tire clearance can be tight, especially with the upper control arms (UCA). Many people run this size with a lift, but it can depend on the specific setup, like wheel offset. Some minor rubbing might occur without spacers, particularly during full steering lock or flex. It's advisable to test fit and inspect the clearance to avoid issues. As a business management student, I struggled with writing an essay on business growth. I shared my problem with my cousin, and he suggested the service "DoMyPaper." After checking online reviews and finding them to be positive, I decided to try https://domypaper.com/ for assistance, and it turned out to be one of the best decisions I ever made. DoMyPaper offers excellent service at affordable rates, making it a budget-friendly option. They delivered high-quality content without any plagiarism.
Wow
