NorCal SOLD - KBVoodoo/ Max Modular Aluminum Bed Rack
Brijen
The rack I’m selling is the Max Modular aluminum 10” rack. This is the long bed, 58” version (edit: does work on a short bed as well, see below comments). The rack is like new and has been assembled (now taken back apart) but never used - didn’t work with my setup. The brackets I have are the bakflip tonneau brackets so assume you may need to purchase new brackets which is around $125 unless you use a bakflip cover on the long bed truck. Happy to provide more info if needed.
Here’s the link to this specific item:
$500 local pickup only.
Also just piping in here, but I believe the long version does fit on a short bed Tacoma... so that might widen your net of potential buyers. Hopefully I’m not wrong on that
You are correct. The long bed rack does work on a short bed Tacoma, just not if you have a bakflip cover. If you are looking to use this with a bakflip cover, you need to have a long bed. Any other cover or no cover at all and this works on either bed size.
Thanks for the input ^
