YEs I will definitely look at that when i get some. I did install SPC UCA and had the tires moved forwarded some to help with the rubbing issue.Whatever combo you run, I'd be concerned that your chains will regularly make contact with your fender liner, fender well, or cab mount. Your chosen tire size puts you right in the realm of possible clearance issues. So you'll have to check your setup carefully.
This^^ it’s in the manual too FYI. Not being a jerk I just Don’t remember the specifics off the top of my head. But I remember Seeing it.Irrelevant for chains, though. You should only run chains on the rear wheels, unless you like destroying brake lines.
CBob,I'm on my 32nd winter in Colorado.
The only time I've used chains was for getting through a few feet of fresh to haul an elk out of the backcountry.
All terrains work great, and winter specific siped tires even better.
I ran studded bfg's on a older yota with lincoln lockers, cause it would get so squirrelly.
But never drove over monarch pass wishing I had chains.
Don't even own them.
Our snow is typically a little easier to drive on then back east or midwest snow.
Dry, cold and grippy in comparison.
We don't salt much here either.
We put down gravel, the size that cracks your windshield.
And welcome to Colorado.
Hope you have a great winter.
Great information.! We been in Fraser Co for 3 year on and off and now here full time.Ive lived in Crested Butte for 32 years now, and pulled a snowmobile trailer too.
I've never needed chains.
If 70 gets bad it will close because of avy danger or wrecks.
We do all of our Dr appointments in denver and seems like we are always going over monarch pass in snowy conditions, all terrains are good to go.
You will be fine with the KOs
The snow up in the mtns wilk be dryer than denver snow, and less slippery.
If there is enough snow on a forest rd to think about chains just unload the sleds there.
The only exception would be getting stuck up high elevation in a hunting camp after a 3 footer.
Seen that on a Halloween storm.
We were on sleds up kebler pass and saw hunters trying to get out of camp. They had a rough time.
Snowmobile club pulled them out with a snow cat.
