SDHQ Built 2016+ Double Cab Long Bed Sliders
SDHQ OFFROAD
sdhqoffroad.com
SDHQ is proud to announce the release of our own set of Rock Sliders for the 2016-Current Toyota Tacoma Double Cab Long Bed. Sticking to a well earned reputation for craftsmanship, we chose to build these rock sliders out of 4130 chrome-moly tubing with gusseted steel mounting plates ensuring that these are both the strongest and lightest rock sliders on the market. These rock sliders are CAD designed and built in house for a precise fit and finish. Our rock sliders use a unique mounting design that is intended to be a fully bolt on design that reaches the entirety of the slider, so there is no cutting, welding or drilling required for install and there is no permanent frame modifications required. All mounting hardware is included with the purchase of your SDHQ Built Sliders
FEATURES:
  • Fits 2016-Current Double Cab Long Bed Toyota Tacoma
  • Durable 4130 .120” wall Chromoly tubing with gusseted steel mounting plates for durability
  • No cutting, drilling or welding is required for install
  • No permanent modification to the frame is required
  • Unique mounting design made specifically for the Toyota Tacoma
  • Slider is supported at the very front and back to ensure no weak areas
  • Just as strong as a welded slider
  • 5 mounting points along the frame
  • Works with body mount chops
  • CAD designed for a precise fit and finish
  • High strength grade 8 hardware included
  • Raw and powder coated finishes available
https://sdhqoffroad.com/collections...oyota-tacoma-long-bed-sdhq-built-rock-sliders
hellppy
FEATURES:
Mine got used and abused yesterday! they took a damn beating and didn't budge! So happy with them!
