Recovery/winch bumper that doesn’t require cutting
ChrisChuck
First post in here. Wondering if anyone has any recommendations for a front end winch bumper that doesn’t require cutting of the factory bumper. I really like the SSO Slimline Hybrid Bumper, but that will require me to cut a good portion of the stock bumper off. I’m not 100% against cutting, but would like to avoid it if possible.
Im in Colorado and drive a 2019 TRD OR DCLB. Looking to add some recoverability to my rig so that I can confidently hit the trails next winter. Thanks in advance.
Most anything, including the "no cut" options require some sort of cutting. It may be a small trim here and there, or complete cut off of sections of the bumper, but it's cutting. The different slim style bumpers also vary in how much needs to be cut off.
Have you looked into a hidden winch mount? They hide under the factory bumper and only require you to cut through the lower center section which is easily replaceable later on if you decide to go back to stock.
Here's my truck when I used to have one.
Have you found your bumper yet? The hidden winch mount probably requires the least amount of cutting. After that you’d be looking at a low profile bumper like the one from SOS. @UploadAdventure
There are few no cuts. I think Victory4x4 has one. Plus there are some bull bars.
After over a year of studying. Looking. Researching. And following other people with bumpers the best answer is...... you have to do minor cutting pretty much with any bumper. But ultimately it’s up to your comfort level.
I’m sort of biased as I push SOS Concepts Offroad products. For living in Colorado and doing even mild wheeling I’d get something like a streamline bumper. This way you get solid recovery points and a place to install a winch. I know when I was in Colorado this last year I played it safe, but I had seen many trails where a winch and or front recovery points would have been really important to have. This is just my .02 cents.
Oh and one last note. SOS steel streamline bumper only weighs 65 lbs with no hoop and 70 lbs with a hoop... so you’re not putting that much extra weight on the front end.
Warn Hidden Winch Bumper only requires you to trim a 1/2" piece about 6" long and it cannot be seen. It doesn't affect the TSS at all but it does on the Pro models.
