Pre- Black Friday Sale!!
ragofabrication
ragofabrication.com
Pre-Black Friday deals will be ending on Sunday. There will be DIFFERENT sales for Black Friday so don't delay on these great deals.
STAINLESS STEEL DIFFERENCE
Stronger than steel
Nonmagnetic
Will not corrode or rust
Lifetime RUST FREE GUARANTEE
[IMG]
[IMG]
5TH GEN TOYOTA 4RUNNER MODULAR STORAGE PANEL SYSTEM
Made in the USA
No Drilling Required
Stainless Steel Hardware
Billet Aluminum Stand-Offs
Stainless Steel Bottle Opener
Raw Steel*
Laser Cut and CNC Bent 1/8" Cold Rolled Steel
Hand Sanded to Ensure a Even Surface
Shape Conforms to the Window and Shape of the Body
Designed by Rago Fabrication - Veteran Family Owned Business
3 Mounting Locations - Including a Wide Platform to ensure strength and reduce rattle.
[IMG]
[IMG]
TOYOTA TACOMA REAR SHOCK GUARDS
The Rago Fabrication Shock Guards were designed to keep your shocks safe and free of damage. The rugged angular design creates a guard that can withstand the most demanding trails. In addition to protecting the most exposed part of the shock, the guard also extends to protect the shock shaft from pits and abuse, extending shock life from leaks and tears of the shock shaft seal. Our design also includes a drain hole placed at the lowest point of the guard to prevent lingering of water during water crossings.
American Made
Completely bolt-on. No drilling required.
Increase the longevity of your shocks with the Rago Fabrication shock guards.
Material: 3/16th Steel powder coated black.
King shock compatible.
NOT COMPATIBLE WITH ICON RXT STYLE SHOCK
[IMG]
[IMG]
TOYOTA BED RAIL - HI-LIFT JACK MOUNTS
The mounts are CAD designed, CNC cut, CNC bent, and welded by Rago Fabrication. They come with high torque knobs. Rago Fabrication designed and made the knobs in house with 1/2 inch bolts that are welded internally. They will never break away from over tightening like the plastic knobs are known for.
HIDDEN BUMPER LED BRACKETS
Made in the USA
Easy Installation
No Trimming or Cutting of Bumper
Fit Most 30-32" Single and Dual Row LED Bars
Powder coated Textured Black
Lifetime Warranty and the Rago Promise – Satisfaction Guarantee
Patent Number: US D784, 114S
[IMG]
TACOMA 2ND & 3RD GEN BOLT-ON ROCK SLIDERS
Rago Fabrication has set a new standard in the rock slider market. These rock sliders feature a new design that hugs the frame 360 degrees while still being bolt on. The frame mounts are fully boxed made from 3/16th steel and could not get any beefier. We only use 1 3/4 .120 wall DOM tubing because we believe seam walled tubing, although sufficient, will not stand up to the extreme off-road environment. Our design is streamlined, low profile, and flows nicely with the factory body lines.
[IMG]
[IMG]
BLEMISHED - 2ND GEN TACOMA DITCH BRACKETS
Made in the USA
CNC Cut 3/16 Stainless Steel
No Drilling or Trimming Required
Bolts on Hood Hinge
Low Profile Clean Look
Blemished: Powder coated Black Textured Black w/ Minor Powder Coating Imperfections
Lifetime Warranty and the Rago Promise – Satisfaction Guaranteed
Designed by Rago Fabrication - Veteran Family Owned Business​
