SoCal Part Out! Available now - Wheels, suspension, sliders, spacers, tonneau cover, lights
  • Thread starter Thread starter itsthex
  • Replies Replies 0
  • Views Views 741
itsthex
5️⃣ Platinum
Hey guys! Unfortunately selling the truck. Life! All of these parts are off the truck and are now for sale. Don't hesitate to reach out.
I can also offer checkout through PayPal so you can use their available PayPal financing options for the expensive stuff.
Located in Inland Empire, CA
Here's a few shots of the truck for reference.
Parts and prices:
Locked Offroad full 2.5" extended travel coilover kit (front and rear, stock replacement) - $2000
  • Great performing kit, comparable to FOX
  • ~5,000 miles
  • 650 lb springs, ride height set for stock weight (~2.25" lift in front)
  • No wait, available now
https://www.lockedoffroad.com/collections/3g-tacoma-2016/products/toyota-tacoma-2-5-shock-package
Accutune Tubular Spherical Front UCA's - $750
- Perfect condition
https://accutuneoffroad.com/product...H_yZuu7OXuOmDkMZVg-zMVVKc9cSQUD4aAk4FEALw_wcB
Accutune N98 (J66 hybrid) leaf pack - $800
  • Bushings still in excellent condition
  • ~2.25" lift on stock weight truck
  • Rides like stock but slightly softer, good for stock weight or +300lb/towing
https://accutuneoffroad.com/product/deaver-n98-2-lift-leaf-springs-05-up-tacoma/
Accutune U-Bolt flip with Progressive bump Stops - $300
  • Bump stops in perfect condition
  • Height set appropriately for this setup (can be changed, contact accutune)
https://accutuneoffroad.com/product/accutune-offroad-u-bolt-flip-kit-05-toyota-tacoma/
4 Wheel Parts Heavy Duty Rock Sliders with Kickout - $750
  • Light scratches from bushes, etc
  • Never touched a single rock
  • Excellent condition
https://www.4wheelparts.com/p/4-whe...rs-with-rear-kickouts-61648w/_/R-4WPBR-61648W
(4) BORA 1" Bolt-on Wheel Spacers - $200
- Currently installed on the truck
(4) Spidertraxx 1.25" Bolt-on Wheel Spacers - $200
- Available to ship now!
SOLD Bakflip F1 Tonneau Cover - $SOLD
  • Perfect condition, all hardware included and not damaged
  • Bolts straight in, no modification to the truck needed
  • Relocates factory tie-down bars so they can still be used
  • Holds up to 400lbs on top of cover
https://realtruck.com/p/bakflip-f1-...eYx2l6Rbl4LEWtfy2HUguCj1iehuYmy8aAgcbEALw_wcB
Diode Dynamics SS3 Fog Lights - $200
  • Direct bolt in
  • 1 repaired bracket
  • Amber, DOT Approved (won't blind everyone on the road, still works amazing offroad)
https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2016-2023-toyota-tacoma.html
Cali Raised Hidden Light Bar Brackets with Light Bar - $125
  • Will come with all wiring and necessary hardware
  • High Quality Amazon brand lightbar (Spot focus center lights, spread outer)
https://caliraisedled.com/products/2016-2021-toyota-tacoma-32-lower-bumper-hidden-led-light-bar-kit
(2) Trigger One Bluetooth Relay - $50
  • Directly replaces most light and accessory relays
  • Allows control of accessories via bluetooth on your phone!
  • Removes necessity to run wiring and switches in the cab (clean install)
(4) Classic 1997 spec Rays Power Volk 2pc wheels (16x7, +25 offset) with Yokohama Geolander 255/85r16 tires @ 50% tread (plus one spare unmounted tire, same size) - $2750 OBO
  • Ultra light, similar to modern Rays Volk wheels at 16.5lbs
  • Practically unattainable in this color and condition
  • Fully restored, all new hardware
  • Same as stock wheel offset on 3rd gen, but needs at least 5mm spacer to clear brake calipers
  • If using 5mm spacer, shouldn't rub at all on cab or chassis!
  • Currently setup on truck using 1" spacers as seen in photo
Thanks for looking!
