- Joined
- Feb 22, 2020
- 504
- 538
Midnight Black
Just stumbled on this: https://www.jlttruecoldair.com/jlt-3-0-oil-separator-2016-2020-toyota-tacoma-3-5l/
Says its more useful for forced induction vehicles, but I can't make sense of this:
Is there really so much oil in vapor form going to the air intake side of the engine? Is this similar (identical?) to folks putting oil filters / breathers on import cars and bypassing the breather line to the intake?
During the process of venting crankcase pressure back through your intake track, large amounts of oil in the form of vapors can coat your blower rotors, intake valves, intercooler fins, and even dilute your gas lowering its octane level. This happens on all engines and is even worse when supercharged and turbocharged as crankcase pressures are increased. To combat this, we have developed an oil separator of our own design. Milled from solid billet aluminum this is a rock-solid piece. It has a knurled tank base for easy removal to drain the spent oil and an O-ring seal to prevent any leaks.
