- Joined
- Aug 24, 2018
- 196
- 230
- Location
- Las Vegas, NV
- Website
- www.battlebornoffroad.net
Nitro Upper Control Arms Extended Travel Ball joint style (Pair)
Nitro Gear & Axle has launched their new tubular upper control arms for 2003+ 4Runner, 2005+ Tacoma, and 2007+ FJ Cruiser. These upper control arms feature Heavy Duty Grease-able Sealed ball joint that offers higher misalignment than OEM, and lasts much longer than uniball type arms, and no squeaks!!! OEM style Rubber bushings for lower maintenance, quieter, less vibration and no squeaks!- Heavy wall tubular design provides more strength versus the flimsy OEM stamped steel arms. They also feature Lower profile than OEM Arms, thus providing additional clearance for larger tires, and/or larger/ longer shocks. Finally, they offer Removable Billet ball joint Top Caps, 3 Degrees of additional Caster, and will work on stock height vehicles as well as lifted vehicles. These arms are 100% bolt on and will not require any modification to your vehicle! Order yours today below!!
Use promo code T3G for the deepest discount on these arms available!
Click Here to purchase your set today!
MSRP: $866.24
Your T3G Price: $736.30
Highlights:
- The arms are 100% BOLT-ON
- Heavy Duty Grease-able Sealed ball joint offers higher misalignment than OEM, and lasts much longer than uniball type arms, and no squeaks!
- Removable Billet ball joint Top Cap
- OEM style Rubber bushings for lower maintenance, quieter, less vibration and no squeaks!- Heavy wall tubular design provides more strength versus the flimsy OEM stamped steel arms.
- Lower profile than OE, thus providing additional clearance for larger tires, and/or larger/ longer shocks.
- 3 Degrees additional caster.
- Will work on stock height vehicles as well.
