Brand new from New Holland Overland is the Off-Road Trailer Chassis Roller! This trailer frame is designed for the DIY'er!
Getting all the hard and dirty work done of creating a rugged off-road purposed frame, this gives you the perfect platform to build your trailer to your spec's!
Trailer Frame Roller Info: $3,675
- Trailer Body Build Platform Dimensions (48"W x 107"L)
- Trailer overall Dimensions (72"W x 120"L)
- Top of the frame sits 24" above the ground
- Timbren Independent Suspension 4" lift 2,200lb axles
- Yields 21" of ground clearance with 285/70/17 tires
- 2.5" of deflection (suspension travel)
- 2"x3" Steel square tube frame with 1.5" round tube sliders/fenders
- Max Coupler
- 3-axis rotating hitch system
- (x4) Shackle/Recovery points
- Rear receiver for bike racks, RIGD Ultra Swing, etc.
- All LED DOT approved lighting
- Method Wheels (17")
- Will determine lug spacing by customer's vehicle
- Can change wheel if customer requests (Additional charges may apply)
- BFGoodrich K02's 285/70/17 (33"s)
- Can change tire if customer requests (Additional charges may apply)
PRE ORDERS ARE LIVE ON THE WEBSITE:
Trailer Chassis Roller | NewHollandOverlandCo
PRE-ORDER LIVE *Production will begin in JanuaryThis trailer frame is designed for the DIY'er! Getting all the hard and dirty work done of creating a rugged off-road purposed frame, this gives you the perfect platform to build your trailer to your spec's!Trailer Frame Info: Trailer Body Build...www.newhollandoverland.com
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
