That is the real question I didn't ask. Sky's the limit really.How much do you want to spend?
Good thing about that tire size, is you can run them with stock suspension. I ran my wheels/tires for about a month. Only rubbing I encountered was the front mudflap. I just removed them.Yeah that honestly sounds like the sweet spot for what I’m after. I’m trying to stay around the $1k–$1.5k range for suspension before tires, so the Bilstein 5100 route is sounding more and more appealing compared to jumping straight into expensive coilovers.
I mostly daily drive the truck (300 plus highway miles some weeks myself) with occasional light trails and camping trips, so ride quality matters more to me than max articulation. The 5100s on the 3rd notch with the 1” rear block and 265/70/17 Falken Wildpeaks honestly sounds like a really balanced setup with minimal rubbing/headaches.
Good call on the ECGS bushing too I keep hearing about the needle bearing issue on these trucks, so doing it while everything is apart makes sense for peace of mind. Appreciate the detailed breakdown.
