www.ovtuned.com
I don't know how the automatic transmission is, but, with my MT i don't have any power unless i am in 1st gear. I didn't buy my Tacoma for power, but it's annoying that I have to find a dry spot, or a safe spot, and downshift to 1st gear before I go through mud, snow, or climb a hill. The engine is very responsive when I put the Tacoma into 4 low. Would the OV Tune get me more power in at least 2nd gear?
I'm interested in the tune as well. the throttle is super laggy. I just want to tighten it up. when I push on the gas I mean it.Looking at Marlin Crawlers TacoBox
Will be calling OV turn for sure
Happy with it until i regearedJust adding another option to the mix. The Pedal Commander is another option for what you're describing as well. It doesn't change the tune at all, or add any power, but it works by changing the feel of the pedal. A lot of people are very happy with the stock tune and it. @Malcolm has used it and seemed pretty happy with it as well.
Yeah for sure, I've thought about the PC. I've heard some mixed reviews for long term use. Just hard to come from a Civic Si that goes when you push the gas, to the Tacoma that hesitates and bogs then goes. very trivial and not a deal breaker by any means.Just adding another option to the mix. The Pedal Commander is another option for what you're describing as well. It doesn't change the tune at all, or add any power, but it works by changing the feel of the pedal. A lot of people are very happy with the stock tune and it. @Malcolm has used it and seemed pretty happy with it as well.
I want to do the OVtune thing as well, but 50% of my driving is freeway..from dead stop on I-80 in Sacramento, to 70mph..will this drastically affect my gas mileage in a negative way? Super new to the Tacoma world of life
How fast are the tunes normally out of beta? I’m guessing it’ll technically do some warranty voiding if Toyota wanted to play that game?
Yes. It sure would effect your warranty of Toyota knew what you were doing. That said the tune is undetectable at the dealer. They can't read the ecu program in that way.
How did the regearing change the performance? Does it increase throttle response or mpg? I'm scraping by on 15mpg now that i upgraded to 285s, and the performance suffered dramatically from 265.Happy with it until i regeared
The 4.88’s I did made the power more accessible, I did go to 33’s and added weight. Believe it or not, still haven’t installed the tune
Trying to “find “ which is the 4.88 tune
have been distracted
running the performance tune at the moment
www.ovtuned.com
