Lift Help!
Jharris704
I'm ready to buy a lift for my 2019 DCSB TRD Off Road. The truck is my daily driver so I want to maintain a nice ride. I will also be using the truck to tow 4 wheelers and some possible "light" off roading.
I've been reading all of the different lift threads here and think I have a good idea of what to get.
5100s with 888 coils and the HD leaf pack. (Anyone know if the rear shocks are 5100s? It just says RCD/Bilstein Extended length rear shocks.)
https://www.headstrongoffroad.com/store/p402/Coil/Bilstein_5100_Kit_w/_Dakars_(HS16BK-1-Dakar).html
Will I need something extra in the front to make it level since it would be 2in for front and back?
Is spending the extra on full leaf packs for the back worth the money? Vs a cheaper add a leaf?
I am also looking to upgrade wheels and tires. Thinking about a 17in rim with 285/70 all terrain tires. Looking at the Falken WildPeak A/T3w as they are about $200 cheaper than the k02s.
I'm trying to think about it as do it right the first time while trying to justify spending this much on a brand new truck. Thanks for any help!
Rears are 5100s too.
Are you running armor on front? I think 888 are for heavier weight.
Hit up Headstrong on perch settings about leveling. Full leaf pack is always recommended if it can fit your budget. Stock leafs will start to sag over time especially if adding weight.
Thanks for replying. The 888 are mid springs. I would like to go with a bumper in the future. Figured it would be better to get those now then have to buy more when I did add the bumper.
Kind of thought I would need a small spacer added to the front to make it level. The front and back both say 2in lift. So anything other than the top setting sounds like it would make it less leveled out in the front.
