KING SHOCKS BACK IN STOCK AT BATTLE BORN OFFROAD
We have a brand new batch of King Shocks back in stock at our shop! Don't get stuck with a 4-6 week lead time! We have both extended travel and standard travel in stock, as well with and without adjusters! Available quantities will be below, and will first come first serve. If you have any questions feel free to message us, or would like to set up a package with control arms and leaf springs we can add on an additional DISCOUNT!
LINK TO ALL SHOCKS BELOW!
Why King Shocks?
Why King Shocks?
- Lightweight hard anodized 6063 aluminum alloy reservoirs dissipate heat quickly and will not rust due to gas charging contamination.
- The heat treated 6061 aluminum alloy piston has our highly developed port configurations that contribute to the unique damping performance and famous King ride quality.
- High quality fittings are mated to Aeroquip high pressure hoses which resist abrasion and kinking.
- Wear bands are made from a Rulon composite that offers incredible wear resistance, low deformation under load and high compressive strength. Overlapping end design enhances sealing.
- Internally threaded top cap design threads over the shock body to enable maximum piston travel inside the shock body.
- Large 3/4" or 7/8" diameter shafts have a minimum tensile strength of 100,000 pounds per square inch. They are hard chromed and micro-polished to a 6 RA finish for extended seal life.
- 2.5" Shock cylinders are precision bored to within +/- .001, then honed after cadmium plating to remove buildup for a tight piston seal and optimum valving function.
- High strength rod end designed for proper clearance on your application. Steel Teflon lined spherical bearings for smooth articulation and long life with no metal to metal contact.
- Coilover shocks are machined with our own truncated thread design for ultimate strength and trouble free spring preload and height adjustments.
- Aluminum components and vehicle specific mounts are machined from aircraft quality billet. Front and rear kits all include all necessary vehicle specific mounting brackets and hardware along with detailed installation instructions. Technical support, if needed, is only a phone call or email away.
- Pinch bolt coil adjuster nut offers superior clamping force to retain your coil preload adjustments without crushing the threads like set screw style collars do.
FREE SHIPPING ON ALL SHOCKS
NO TAX OUTSIDE OF NEVADA
USE PROMO CODE T3G FOR AN ADDITIONAL DISCOUNT
WE PRICE MATCH ALL COMPETITORS
KING FRONT SHOCKS
QUANTITY AVAILABLE : 3
CLICK HERE - King 2.5 Front Shocks w/ Remote Reservoir & Adjusters
QUANTITY AVAILABLE : 5
CLICK HERE - King 2.5 Front Shocks Remote Reservoir - Extended Travel
CLICK HERE - King 2.5 Coilovers w/ Remote Reservoir & Adjusters - Extended Travel
KING REAR SHOCKS
QUANTITY AVAILABLE : 10
CLICK HERE - King 2.5 Rear Shocks w/ Remote Reservoir & Adjusters
QUANTITY AVAILABLE : 8
CLICK HERE- King 2.5 Rear Shocks w/ Remote Reservoir
QUANTITY AVAILABLE : 7
CLICK HERE - King 2.5 Rear Shocks w/ Remote Reservoir & Adjusters - Extended Travel
