Ignition coil problems
  • Thread starter Thread starter haas.evan
  • Replies Replies 7
  • Views Views 7K
haas.evan
The other day my truck threw a P0352 code (Ignition Coil B Primary/Secondary Circuit Malfunction). Earlier in the year, I replaced my old ignition coils with RIPP coils but kept the old set in my garage. When the code popped up, I put the old ignition coils back and hoping to have fixed the issue. Instead I got a P0352 and P0354 fault. So next I moved ignition coils around and got P0352, P0353, and P0354.
Every time I move these ignition coils around it seems like I get a new fault. I went ahead and ordered new spark plugs and new ignition coils and plan on replacing all everything. Can anyone think of anything I've missed? Or what might be causing this cascading failure?
Could be a bad connection. Could be a pin in a connector.
These pins/wires will come out of place if pulled on.
Always try to use the plastic body of the connector to pull / push on.
How long/how many miles did you put on before the code after the initial coil swap?
I noticed doing mine some of the wires are kind of tight. I could see something getting pulled too much and maybe causing an issue.
The new ignition coils were about a year old. The connections all looked good and I double checked them after swapping things out. I'll make sure to keep it in mind, but I don't think that's the issue.
Toyota Tacoma bad ignition coils symptoms, causes, and diagnosis​
The ignition coils are part of the ignition system in Toyota Tacoma, responsible for amplifying the relatively low battery voltage from 12V to a high voltage of tens of thousands of volts for the spark plugs. Driving your Tacoma with bad ignition coils can damage the engine or the catalytic converter, so you must act urgently to avoid more expensive repairs.
Toyota Tacoma
Toyota Tacoma – (Jonathan Weiss / Shutterstock)
The most common signs of bad ignition coils in Toyota Tacoma are engine hesitation when accelerating or loss of power, rough idle, misfires, excessive fuel consumption, check engine light illuminates, and sometimes hard starting. In worst case scenario, if the ignition coils are in really bad condition, the engine will not start.
Symptoms​
Check engine light illuminates due to misfires​
When an ignition coil start to fail or has failed in your Tacoma, it will cause the engine to misfire and the check engine light may illuminate in the instrument cluster. To perform further diagnostics, you will need to connect an OBD2 scanner to your vehicle. If you see any error code from P0300 to P0312, it indicates that there are misfires in the engine. However, it can happen that there are no error codes. In case of doubt, check the condition of the ignition coils and replace them if found defective.
Poor acceleration​
If the ignition coils are not working properly, the engine will lose power. When you press the gas pedal in your Tacoma, the vehicle may hesitate to accelerate and it will take longer to reach your desired speed.
Rough idle​
Another indication of bad ignition coils in Toyota Tacoma is rough idle. The engine will not run smooth when idling, and you may also feel vibrations in the cabin.
Poor fuel economy​
Excessive fuel consumption is a common sign of bad ignition coils or spark plugs in Tacoma. If your vehicle is getting significantly lower gas mileage than usual, its time to inspect the condition of the ignition coils and spark plugs.
Hard starting​
When the ignition coils go bad, it is going to take longer for the engine to turn over and start. The ignition system in your Tacoma will have to work a lot harder to be able to ignite the air/fuel mixture in the combustion chambers.
No start​
Your Tacoma may not start if most of the ignition coils have failed, as the spark plugs will not produce proper sparks due to insufficient ignition energy.
Can you repair a bad ignition coil in Tacoma?​
A faulty ignition coil cannot be repaired; it must be replaced with a new one. However, in some cases, if the ignition coil has been contaminated due to an oil leak in the spark plug tube/well and the end of ignition coil boot has not become mushy, you may be able to restore its functionality by cleaning it with an electronic cleaner or MAF sensor cleaner. Nevertheless, If you see corrosion or rust on any ignition coil of your Tacoma, it must be replaced
How to check for a bad ignition coil in Toyota Tacoma?​
The fastest and easiest way to check for a bad ignition coil in Tacoma that has check engine light on for misfire is to swap the ignition coil on the misfiring cylinder with another coil.
  1. Plug a scan tool to the OBD2 port in your Tacoma.
  2. Read the error code, for example if it says P0303, it means the cylinder number 3 is experiencing misfires.
  3. Turn off your Tacoma and let the engine cool down to prevent any burn injury.
  4. Remove the ignition coil from cylinder 3 and swap it with any other cylinder, for example cylinder 2.
    Caution: Do not swap the spark plug wires/connectors, only the ignition coils. Unplug the electrical connectors before swapping and then reconnect after the swap.
  5. Start your Tacoma and read the error codes with a scan tool.
  6. If it shows error code P0302 which indicates a misfire on cylinder number 2 and there are no misfires on cylinder number 3, it means that the ignition coil is defective and should be replaced.
Note: This method only works on vehicles with coil-on-plug (COP) type ignition coils, and will not work on coil packs.
Can I replace just one ignition coil?​
Yes, you can replace just the defective ignition coil in your Tacoma. However, as a general rule, it is recommended to replace all the ignition coils at once as a preventative measure. This is because when one coil fails, another isn’t too far behind, especially if the vehicle has racked up over 100,000 miles.
Typically, ignition coils last around 100,000 miles or more under normal conditions.
If your vehicle is equipped with coil pack in which a group of ignition coils are physically connected together, you will have to replace the whole pack.
What causes ignition coils to go bad in Toyota Tacoma?​
Ignition coils are subject to wear and tear under normal driving conditions, and will fail eventually, which happens mostly around 100,000 miles mark. Ignition coils can fail prematurely in Tacoma for a variety of reasons including overheating, vibration, moisture intrusion, engine oil leak, or issues with other components of the ignition system, such as bad spark plugs can cause a coil to output higher voltage than normal, significantly reducing its operating life.
Oil leak in spark plug wells​
An oil leak in the spark plug tube can hinder the normal operation of the ignition coil in Toyota Tacoma, cause the engine to misfire, and can even damage the coil. This usually happens due to a leak in the spark plug tube seal in the valve cover. Replacing these seals mostly fixes the leak.
Rodent damage or faulty connector/wires​
If bite marks are discovered under the hood, there is a high probability that a rodent has let off steam in the engine compartment of your Tacoma. Then it is important to carefully examine all the cables and hoses for damage, including electrical wires and connectors for the ignition coils.
When the electrical wires or the connector for the ignition coil goes bad, you may see an error code between P0350 to P0362 when you hook up a code scanner tool, which indicates an ignition coil circuit malfunction.
Blown fuse​
The ignition coils in Toyota Tacoma needs electricity to work. In case of a faulty fuse, the circuit is interrupted and the coils will not fire. Check the owners manual or the fuse box cover of your vehicle to find the exact location of the fuse for the coils. If the fuse is blown, replace it with a new one with the specified amp rating.
To check the fuse, pull it out of the fuse box using a fuse puller or needle nose plier and hold it against the light. If the metal strip is broken in the middle, the fuse has blown. You must replace it with one of the same amperage and therefore the same color. It does not matter in which direction you insert the fuse.
Does the ignition coil order matter?​
When replacing ignition coils in your Tacoma, it does not matter which order the coils go in or if they get switched around. But what does matter is the order of spark plug wires or connectors; with the help of the labels on the connectors, make sure each connector is hooked up to its matched cylinder. Connecting ignition coil wires in the wrong order can affect the performance of the engine or prevent it from starting, and can even result in engine damage. Mostly, due to the fixed arrangement of the connectors and wires, it is not possible to swap the connectors, even by mistake.
Can you drive Tacoma with a bad ignition coil?​
It is possible to drive your Toyota Tacoma with a bad ignition coil, but not recommended – as it can damage other components in your vehicle.
Spark plug fouling​
A fault in an ignition coil can cause misfires due to poor sparking which can foul the related spark plugs.
Catalytic converter failure​
If you continue driving your Tacoma with faulty ignition coils for extended period of time, it can cause total meltdown of the catalytic converter. Since a bad ignition coil cause the engine to misfire, any unburnt fuel that escapes from the combustion chamber will ignite inside the catalytic converter which will overheat it. Repeated overheating can melt the internal structures and will eventually clog the catalytic converter, which will then need to be replaced at a high cost.
Catalytic converters contain honeycomb-like structures with tiny pores that are coated with platinum, rhodium, or palladium depending on the catalyst stage. If these pores get clogged due to improper engine combustion (e.g. because of bad ignition coils), the exhaust gases cannot pass through easily. This suffocates the engine and causes performance issues.
Will a bad ignition coil throw a code?​
A faulty ignition coil can cause an engine to misfire, when this happens you may see an error code from P0300 to P0312 depending on which cylinder is experiencing misfires. Additionally, you may see error codes from P0350 to P0362, which indicates a circuit malfunction e.g. broken wires or faulty connector.
What would cause an ignition coil not to fire?​
If the ignition coils are not firing properly in Tacoma, it can be due to a variety of reasons including defective ignition coils, malfunctioning crankshaft position sensor, bad wire in primary circuit, bad electrical connector, or faulty ECM/PCM.
Should I replace spark plugs with ignition coils?​
It is a common practice to replace the spark plugs when replacing ignition coils in Tacoma, especially when the spark plugs have been used for some time. Worn spark plugs can cause the ignition coils to work harder, producing higher voltage than normal, which significantly reduces its operating life.
Do better ignition coils increase horsepower?​
Simple answer is no, unless the existing ones in Tacoma are defective. Aftermarket ignition coils installed in a stock engine do not increase horsepower, or improve fuel economy, or make the engine run any smoother.
Use OBD2 scanner for diagnosis​
Since Toyota Tacoma is equipped with on-board diagnostics (OBD), a fault diagnosis can provide initial indications of where the malfunction is located.
OBD2 scanners are now available in various designs. You can use a standalone diagnostic device (shown above) or get an OBD2 adapter that connects with a smartphone app via Bluetooth or WiFi.
To begin troubleshooting, you must first connect the diagnostic tool to your Tacoma. The OBDII connector is usually located under the dashboard. With the tool connected, turn on the ignition. Most diagnostic devices then ask for some information about the vehicle. It is important that you enter this 100% correctly, otherwise the result of the search may be inaccurate. In addition to the vehicle make, model, and engine type, you usually also have to type in the Vehicle Identification Number (VIN). Since some OBD codes are manufacturer-specific, the scanner will be able to give you more accurate information if you enter more details about your Tacoma.
Conclusion​
If you see noticeable loss of performance or engine hesitation with high fuel consumption in your Toyota Tacoma, you should definitely check the ignition system of your vehicle including spark plugs, ignition coils and their connectors/wires.
In any case, it is advisable for laypersons to visit a workshop. A professional mechanic can swiftly diagnose the problem for you.
Toyota Tacoma
Symptoms​
Poor acceleration​
Rough idle​
Poor fuel economy​
Hard starting​
No start​
Blown fuse​
Spark plug fouling​
Conclusion​
That's a great resource. Thanks for the info. I hadn't found anything quite that good in my online searches.
I must add that aftermarket coils MAY have "requested" more power from the PCM
(thats the whole point MORE power)
This COULD have caused an issue with the PCM
or ANOTHER SENSOR could be bad.
Install STOCK plugs, and coils when they arrive.
If they are installed correctly and the wiring and grounding is good, BUT there still is a issue,...........
A diagnosis from a "Toyota Qualified" master mechanic may find the little problem causing a big issue.
Hope you get things going!
