gene158
So my truck is currently at stock height. I'm running 265/70/17s and even with some trimming, I get just a bit of rubbing when going into steep driveways and stuff. I've been thinking about getting the adjustable bilstein 5100s because I like the adjustability of the front shocks being able to lift as little as .65". I know that this setup won't give me any lift in the rear which if I ran the front spring on the second notch probably wouldn't be an issue. However if I decide to raise the front more than that, I'm gonna want to lift the rear a little bit. What's the simplest/cleanest way to lift the rear an inch or two? Lift blocks? AAL?
