That's strange because I thought the '20 was suppose to have LED'sMy 2020 tacoma has the regular stock headlights.
What would I need to splice to install the new trd led version on my sr5?
Has anyone attempted it yet?
Yeah the trd sport and off road 4x4 are but I guess not the sr5That's strange because I thought the '20 was suppose to have LED's
Thanks for clearing that up for me.Yeah the trd sport and off road 4x4 are but I guess not the sr5
I did some research on some aftermarket brands. Alpharex seems to have the best output, however they didn't compare Form Lighting which I really wish they did... From what I hear, you need to do some splicing or something with the Alpharex's? Morimoto is all plug n play.. So is Form.. I wanna know if anyone has the Form lights before I pull the trigger on somethingThe stock LED headlight setup is a fantastic upgrade to the halogen projectors and there is an adapter harness to connect the OEM leds to the non-led connections available here:
That said, I think the output of the Morimoto XB Gen 2's is better and I think they look much better so that's the option I went with.
Shot of the output from the Mori's:
Re: the other user who put the 2stroke bulbs. I went that way at first also and was not at all satisfied with them. The bulbs a great in other applications, but the Tacoma projectors are garbage. Best to retrofit or change the housing completely.
Might want to do some more research. Morimoto extremely outperforms Alpharex. The peak brightness might be higher due to them having 4 leds, but the usable output is much improved with Mori. Unless you're referring to the OE knock-offs. In which case stay even farther away from those.I did some research on some aftermarket brands. Alpharex seems to have the best output, however they didn't compare Form Lighting which I really wish they did... From what I hear, you need to do some splicing or something with the Alpharex's? Morimoto is all plug n play.. So is Form.. I wanna know if anyone has the Form lights before I pull the trigger on something
Will keep that in mind!Might want to do some more research. Morimoto extremely outperforms Alpharex. The peak brightness might be higher due to them having 4 leds, but the usable output is much improved with Mori. Unless you're referring to the OE knock-offs. In which case stay even farther away from those.
