- 408
- 648
- Location
- NW Washington
- First Name
- Brent
- Truck Year
- 2017
- Truck Color
- White
- Truck Grade
- Off-Road
- Cab & Bed
- Access Cab
- Transmission
- Automatic
- T3G Member
- #4
Installed and wired my ARB dual
A little video I took of it operational on my instagram, feel free to take a look and let me know what you think.
taco_primo
https://expeditionessentials.com/
Bed mount kit with extended wire harness.
Vixen air 3 gallon aluminum tank
ARB QD with dust cover mounted near my rear license plate.
All Stainless steel braided lines with JIC fittings.
ARB Wiring harness after removing all of the electrical tape
Parts of the harness that were not useful (to me)
Harness after it was cleaned up, prior to heat shrinking.
Twin compressor mounted in the expedition essentials bed mount.
QD mounted using a brass bulkhead fitting with ARB dust cover
3 gallon air tank mounted and fully plumbed. I used a T on the exit so that I can run a hard line later up front for a QD under the front bumper in the future.
(My old setup)
After a little trimming I got the ARB switch mounted and wired up. Had a CH4x4 switch but it’s a 3amp switch and I needed a min of a 15amp switch.
And my new setup
Some of the parts i used
Stainless line for connection of QD
https://www.amazon.com/dp/B000YC5IG0/?tag=tacoma3g-20
Bulkhead fitting for QD
https://www.amazon.com/dp/B000MTI1BE/?tag=tacoma3g-20
Tank
https://www.amazon.com/dp/B071PC5VKQ/?tag=tacoma3g-20
I got all of my JIC fittings and lines from
https://www.northridge4x4.com/scp/engine-underhood/on-board-air/compressor-mounts-accessories
Compressor, wire harness extension and mount I bought from
For the install of the compressor mount, make sure to check out @ExpeditionEssentials
youtube video.
follow the instructions and feel free to ask me any questions if neeeded.
P.S. As Jeff says in the video, it is good to have an extra person to help. I did not have help, i did it myself with a bottle jack, a 1 gallon paint can and a 5 gallon paint can.....all stacked on each other, there was cussing and a few beers consumed after. All i am saying is you can do it by yourself but it will be less of a headache if you have a friend. (I did it at 2am after work lol)
taco_primo
(My old setup)
And my new setup
Tank
youtube video.
