E-brake adjustment after rear brake replacement?
CalifExplorer
Just had the honor of going through axle seal replacement, had a good shop do it as that job is beyond my resources. Included full rear brake replacement with OEM parts. The e-brake handle now pulls up to my ear and doesn't feel firm at all. Shop says it'll get better as auto-adjuster gets going and brakes settle in. BS? It wasn't like that when the truck was new with four miles on it, and brakes weren't settled in then either...
Thoughts?
This applies to 2016 and up.
I replaced my drums and had the same issue. Was told it would "auto adjust" over time... it did not. I had to manually adjust the drums on the back until I got a good feel from the brakes and handbrake. There is a rubber grommet on the back of the drums that allows you to put a screw driver through and adjust them. There are a bunch of videos out there showing you how to adjust it if you need it.
