- 320
- 555
- Location
- Tolleson, AZ
- First Name
- Josh
- Truck Year
- 2019
- Truck Color
- Cavalry Blue
- Truck Grade
- Off-Road
- Cab & Bed
- Double Cab, Short Bed
- Transmission
- Automatic
- T3G Member
- #309
It's not as bad as it sounds, but still could've been in serious trouble. Sorry for the long story, but I would appreciate the help! I went on a group run with some Phoenix guys to Box Canyon in Wickenburg, AZ. If you have heard anything about the trail, it's short, but has LOTS of water to play in. I made it to the end of the trail fine, following a few stock Tacomas through the puddles. On the way back, as I was driving into one of the deeper ones, the truck ended up stalling. My back end is submerged (see photo), and lights start coming on. Check engine, oil temp, backup sensor, etc. I get towed out of the puddle I'm in and through another (thank you again Ethan). Every time I would put the truck in drive, it stalled. We unhooked the battery, let it sit for a few minutes, then started it up. I revved the engine after it started and water sprayed out from under the hood, not sure exactly where. After that, it drove fine and I ended up driving home okay without any problems.
I stopped by SDHQ today, and they recommended flushing the front and rear diff (quoted ~$250 parts and labor). Would everyone recommend I do this? I honestly don't know much about engines, but I want to make sure nothing happens down the road.
