Hi all.
Wired up my Caliraised ditch lights and a CH4x4 switch. The switch light stays on when the truck is turned off. I'm presuming this will not be a problem due to the low draw of the switch light, but I'm wondering why this is.
Caliraised lights have 3 wires: blue, white, and black
Switch has 4 wires: red/yellow, red yellow, black, green
Switch black goes to Ditch black
Switch green goes to Ditch blue
Switch Red/yellow goes to Ditch white
I've heard that the other switch red/yellow is to tap into a 12V wire for dash lighting, and didnt know which red/yellow it was. I wired up one of the red/yellow and the top portion of the switch stays lit
I tried the same with the other red/yellow, and the bottom portion of the switch stays lit
Red power is attached to a blue sea fuse block, and the black negative is also connected to the blue sea fuse block.
Any ideas?
Chris
Any ideas?
Chris
