Just a tip for anyone who plans on doing a cmc on their own or having a shop do it.
When doing the cab mount chop, clearance of the body mount to install larger tires, you do not need to cut (notch) the pinchweld and bend it inside- towards frame. Simply bend the pinchweld towards the fender with a BFH and then you can use that lip to attach the lower part of the fender liner to.
Good thing about bending instead of notching-
No sealant needed to “hopefully” seal any holes between the two sheets of metal (future rust area if not 100% sealed
Cannot visually see the pinchweld
It’s a quick tip, if you have questions let me know.
I only took 1 photo of the work while doing it, I did video it. If interested I’ll post it below.
View: https://youtu.be/jZyyAQocu2M
