We are the manufacturer of a few products for the Tacoma 3G and we wanted to share one of those products with you called Bulbzilla. This is a great product to upgrade your halogen low beams and fog lights to more powerful halogen headlight bulbs and get a much better low beam and fog light headlight performance.
BULBZILLA products manufactured by Aspire Auto Accessories allow you to transplant a H9 bulb into any light that uses a H11 bulb (Bulbzilla 11.9 kit).
H11 bulbs are commonly used in low beam headlights and in fog lights. H9 bulbs are commonly used in high beam headlights. Transplanting a H9 bulb for a H11 bulb (Bulbzilla 11.9 kit) gives you a 60% increase in output!
Simply put, there is NO other modification that gives you so much bang for the buck! You can use Bulbzilla as a stand alone product, but using it along with a Brite Box system provides even better results! The 3G Tacoma uses H11's in BOTH low beams and fog lights. Use TWO Bulbzilla kits to switch to H9 bulbs in BOTH low beams and fog lights for maximum light output!
Upgrade both your low beam and fog light output by 60% with our Bulbzilla High Output Bulb Kits made with high temperature ceramic connectors with moisture seals that can withstand a maximum temperature of up to 572º F!
www.aspireautoaccessories.com
If anyone has any questions or needs help purchasing respond to this thread, reach out to us by phone, email, or send us a message.
Here is a picture of the product below:
