Since purchasing my Tacoma in 2016 I have discovered the brakes could use a bit of upgrading. This is my second Toyota pickup the first being a purchased new 1983 long bed 4x4 which had horrible brakes.
While I do not necessarily have any issue with drum rear brakes I would convert to rear discs if it was an economical option. That said I am only looking to upgrade the stock brake configuration with better components. I have a 2.5" lift, 17" rims with larger and heavier tires therefore rolling weight has increased.
I have done quite a bit of research on the subject and have for the moment opted for Stop Tech slotted rotors with Stop Tech 4x4/Towing pads. I'm still waiting on the rotors before I swap out the OEM rotors. While conducting my research I ran across Power Stop brakes, I honestly had never heard of them before. Power Stop appears to garner excellent reviews and they also offer both slotted as well as drilled and slotted brake rotors. What Power Stop offers that apparently no one else does is finned brake drums, there is significant heat reduction using finned brake drums so I can only imagine they are an improvement over OEM.
A bit of background, my Tacoma sees 4x4 use every weekday for work and considerable recreational 4x4 use too. I also tow frequently being extremely mindful to never exceed 75% of towing capacity so brakes are important to me. I will in the near future be replacing all rubber brake hoses with braided stainless and hopefully addressing the E-brake cable tension brought on with my OME BP-51 2.5" lift.
If anyone has experience with Power Stop brakes I would appreciate learning your thoughts. If anyone has successfully addressed E-brake cable tension after installing a lift kit I appreciate learning some ideas in that regard too. Thanks...
