Bigger tire size
Tacornilous
I am currently running 285/70/70 on my truck but am thinking about upping to a 295/70/17 tire.
I have aftermarket upper control arms, OME bp-51 lift kit, and -12/4.5 offset wheels
Is anyone else running a similar setup who knows more info or knows if this is doable without changing the body mount location?
If your alignment is good you shouldn't need to relocate, but you might need to CMC. You can measure and see how close you are to hitting anything. The new tires will stick out half as far as whatever the height difference is. Check clearance at the UCA and the cab mount.
I'm putting 275/60/17 on mine or I may do 275/65/17 they are 30 and 31 but both 11 wide I've got 9 " inch rims 4.5 backset and -12 offset and 1.5 lift they rub full turn smh my 265/70/17 Hankooks dyna - pro are 31.6 tall. Mostly a street truck but we go out on the beach so I don't need heavy lug tires to float over the sand
