GTGallop
My truck came from the dealership with an aftermarket bed cover of unknown manufacturer. It's a three panel hard cover with two panels that flip and fold revealing bed access but the third cover stays put. I've looked it over for some sort of ID information and there is none.
Kind of genius, it has some rails that it sits on bolted inside the bed. Those rails have a channel that is there for strength but also collects rainwater if it makes it past the sealing gasket. At one end of the channel is a cap, at the other (near the cab wall) is a drain tube on each side. Pretty Smart! But then they let the drain tubes loose in the bed so it just drains into the bed. Kinda defeats the whole purpose...
Is it possible that I can drill two more drain holes and route these straight through the bed floor so they drain under the vehicle? Feels like the bed walls and floor is just a fiber reinforced plastic that might drill super easy once a bit grabs hold. What am I missing? What should I be considering?
(Note - Forum required a Prefix. Armor doesn't really fit but seemed closest.)
