8" wide 0 offset wheels
Anyone have a front view profile? Wanna see how far they stick out from fenders on stock suspension before I pull the trigger on 16x8.
@ninong671 this was taken a while ago, but 16x8 no offset on 31” BF Goodrich KO2’s hope it helps.
16x8 method NV305's 0 offset and bfg km3s 285/75/16
Sorry I dont have any perfect head ons but I think they are perfect. Barely stick out of the fenders and I mean barely. Good clearance as far as width is concerned, does not run into the fender like big offsets would, with bp51s set at 20mm preload. With a less aggressive tire they would probly be level with the fender. Hope this helps
@StuckBuck nice ride man! I’m about to move up to that same tire here pretty soon. How’s the gas mileage on those? I have a 42 mile commute so kind of curious what to expect
I'm not too sure the truck only had 600miles on it by time I had the tires on so I dont have anything to compare it to but I just finished a 1000 mile trip and the truck says I averaged 17.5mpg. Seems good enough for me plus I'm kind of a lead foot so I've never been to good at the whole mpg thing lol. Definitely a noticable difference in low end power but I've gotten used to it. I only drive my truck on weekends and trips since I have a cheap little commuter car so I dont have a decent test of commuter miles on the truck but i didnt notice much of a difference.
I have been talking to multiple retailers and they all tell me that the 16x8 wheels scrape (even with a 4.5" BS / 0MM/1 MM OFFSET) with the calipers for the 2018 TACO's... How true is this?
Do your 285s rub the cab mount at all with those rims? If not, how did you do it? If yes, can you share pics of locked wheel near cab mount? Don't wanna get 265s if 285s will work with this offset.
Here I darkened this one up a bit so you can see the edge of the fender a little better. Wish I would have taken the pic without the fog light.
Still hard to see lol I tried
This has me set on methods 0mm offset. Perfect truck, from one cement boi to another ;)
Hi new guy. Seems like StuckBuck hasn't been around since 2018.
But as a fellow cementboii I'm here for you. I didn't do Methods.
But I did go Volks. 16x8. Then Spidertrax 1.25" spacers. Rubbadubdub.
Will be putting these 16x8 on with Falkens 0 offset 265/75 shortly
