3rd gen Tacoma Turbo testing (video)
Some new testing video released the other day.
Current power stats are stated as...
"3.5L Tacoma Base Kit performance :
Torque increase over stock: 145-150%% (340~350 ft lbs)
Horsepower increase over stock: 120-125% (320-325HP)
Peak boost psi : 6.5 psi
3.5L PowerMax Twin Turbo kit Low boost:
Torque increase over stock (160-180%) As Tested ~ 400 ft lbs 2300 rpm
Horsepower increase over stock (150 - 160%) As Tested ~ 375 HP at 5200 rpm
Peak boost pressure 9.5 psi (stable, 2000 to 6000 rpm)
3.5L PowerMax Twin Turbo High Boost :
As tested : 520 ft lbs @ 2500 rpm
As tested : 464HP @ 5600 RPM
Peak boost pressure 21.5 psi ~ 17.5 @ 6000"
Original link: https://youtu.be/L7ZFc_6CTGE
I can’t even imagine driving my truck with these numbers, lol.
Updated info from OVTune
Base kit (assuming you own a flash kit) $4249
Powermax kit (assuming you own a flash kit) $5208
DI upgrade (powermax required) + $1849
Full fuel system upgrade : + 2788.00
if you need a tune kit: + $379 vF Tuner.
estimatedshipping date : June 2020 (this depends on how quickly we can get all the turbos)."
Original link: https://youtu.be/9by2kM7aslw
Video from OVTune, testing their turbo. It does look like a lot of fun, doesn't it?
Would anyone be able to help me with some info or people to reach out to, I’m trying to put a 52mm turbo I took off a 240sx onto my 3rd gen Tacoma but I can only find this twin turbo kit and nothing else, no piping setups, no exhaust manifolds, nothing for me to just put this turbo on. Any help? I probably won’t be on recently much so any info please reach out to my ig @Jc_3.5, thanks!
I'm supercharged and getting identical numbers. I love it
