Maintenance 2WD To 4WD change failure
mariov8595
My 2017 SR5 that has a hazard triangle and “2WD To 4WD change failure” its basically stuck in 2WD. Any common fixes for this? I had removed my switch at one point to do the chrome deletes and it has been like this since.
A quick google search says that means the actuator is stuck inside the transfer case. Unless you somehow seriously botched unplugging and reconnecting the 4wd selector, removing the switch to do the chrome delete should have nothing to do with it. It sounds like an issue inside the TC itself that you just happened to notice after your switch was disconnected. If you have any warranty, bring it by the dealer and let them fix, otherwise it sounds like you need to take a look at the actuator itself and see what's going on.
