Mr.Jay
Testing waters and seeing if interest is there. I have been in debate about switching to Class B for camping needs. I have taken this on the dirt with the Tacoma and its great.
Tacoma pulls it with no concerns what so ever. Its stable and get compliments everywhere.
Both truck and camper look great in person and might seem a bit dirty in pictures. Its been sitting for 2 weeks and took those last pictures this morning.
I use it for winter camping, or posting up at the ski resort the whole day. Winter season is over for me and did it for 2 years, Not sure what Ill do next year. Someone can enjoy during summer.
One corner jack seems to be going up slower depending on the incline. I bought a new one and haven't really replaced or need it to since it just goes up slower. It was 250 and can include.
Has new water pump.
The 20lb propane tank last a very long time. The stove, furnace and refrigerator(great when boondocking and battery is scarce, run off of it and can be used for well over 20 days plus of use.
Everything inside is wood, no composite. Wood flooring and plywood all around inside.
Great build quality.
I thought about getting the exterior wrapped black to compliment the cement color better .
I get compliments every time I use it.
I can include the tie downs torklift on all 4 corners, and rear chasis mounted . I use my sliders custom welded U tie the front. You will have to get something custom made.
New 22k plus year wait.
selling for 14k with tie downs, rear mount. worth 600 alone together.
COPY PASTED INFO.
Has new water pump.
COPY PASTED INFO.
- Dometic 3.7 C.F. 3 way refrigerator
- 12,000 BTU Auto ignition furnace w/ digital thermostat
- Happijac (4220) 4 Corner jacks
- Dometic Glass Top 2 Burner Stove w/ Iron Grate Upgrade
- Single sink with 12 v mini pump
- Single sink w/ single lever faucet w/ pull out sprayer
- Auto ignition water heater w/ exterior port shower & bypass
- Lift up underbed with 2 gas struts
- 17 Gallon fresh water tank(600SS)
- City water inlet
- Marine grade ultra light plywood
- Hand fitted block foam insulation
- Insulated floor
- Fiberglass siding with graphics
- 7-way plug with holder
- 30 amp Twist adapter w/15 amp lighted power cord
- 25 amp power converter/charger
- LPG, CO & Smoke detectors
- 20 lb laydown LPG tank (600SS)
- Pop out pass thru window
- Tinted radius slider dinette window
- 6" Gel Memory/High Density foam mattress
- Screened entrance door w/ dead bolt & gas strut
- Exterior lockable storage
- Exterior rear lockable wing doors (TC650, TC800)
- Front rubber bumpers
- Fire extinguisher
- Interior AGM battery compartment - up to group 31 (600SS) BRAND NEW , HAS 3 CYCLES ON IT
- Interior & exterior 110 v outlets
- 12 v Utility receptacle w/ double USB port
- Maxxfan plus model 00-05100K
- Fantastic Fan with thermostat
- LED interior & patio (3) lighting
- Large folding assist handle
- Lagun swing away table system
- Battery shut off switch
- 1/2 Wrap around rear end w/ LED lights
