2012 - 2015 Tacoma Behind the Grille LED Bar Mounts
SDHQ OFFROAD
sdhqoffroad.com
PRODUCT OVERVIEW:
FITMENT:
2012-2015 Tacoma
- No drilling required
- 3D CAD designed for an OEM quality fit and finish
- Bolts directly to core support
- 1/8" thick steel plate construction for durability
- Stainless steel hardware provided for ultimate corrosion resistance
- Designed for Baja Designs S8 and OnX6 series bars
- OnX6 series DO NOT fit behind standard grilles, only the TRD Pro and aftermarket mesh type grilles
- Rigid SR series will fit in S8 locations
- Ability to run either an S8 or OnX6 series light bar in the middle location with mesh type aftermarket grilles
Difficulty of Installation: Easy
Install Time: Approx. 1 hour
LIGHTING OPTIONS:
Baja Designs
- 30" S8 Series
- 30" OnX6 Series (Only PRO or aftermarket mesh types)
Rigid Industries
- 30" SR Series
WIRING OPTIONS:
Switch Pros
with SDHQ Mounting Solutions recommended for the ultimate install
Air on Board switches are recommended for basic installs
PRO GRILLE:
STANDARD GRILLE:
uaxsxtplyvgbzefx0p0ndexd7qmvovmj50gi4olj_e1c4abfafa4f4a25000d657d3e6f8728cba166a1-jpg.2635400
jteno5qdjvxmoescwvaxw1gzkltm4mzzezwlb8kb_8121d303bacb6df48e50d68a51e9bddecfabf875-jpg.2635401
https://sdhqoffroad.com/collections...-tacoma-behind-the-grille-led-bar-light-mount
