Will 34’s or 35’s fit with a CMC?
agethegeminii
I’m thinking of going 34’s or 35’s, I got 285/75/17 toyo tires R/T, and I want to have a beefer look. Will just having a cmc fit with 34’s or 35’s? I currently have the biltsein 6112/5160s with TC UCA’s. So I only have that 2.5 in lift. What ya’ll think?
you will rub with 315s even with the cmc. i rub in reverse at full lock and entering steep drive ways. i also have the bilstein 6112 at 6/5...
you will rub with 315s even with the cab mount. i rub in reverse at full lock and entering steep drive ways. i also have the bilstein 6112 at 6/5...
Got it, so I should probably go for a relocation kit if I want to avoid the rubbing or probably get a 3in suspension lift. Also I forgot to add that my wheels are -10mm offset.
