SoCal Toyota Tacoma Front Bumper with Light bar and Cube lights
Jasonalex28
Selling my Off Camber Fabrication bumper. Also including the light bar, and set of 4 LED cube lights.
Simple bolt on installation, minor electrical work will be required for installing the lights. I recently bought a CBI T3 so
this bumper and lights are sitting in my garage looking for a new home.
- Off Camber Bumper (Fits 2016-2020 Toyota Tacoma)
- Set of 4 LED Cube lights (White, Amber, and Strobe function)
- 32" light bar
- All wiring and harness
Bumper description
1.75" thick walled tubing construction and heavy duty 10ga. mounting brackets. Modular 3pc design allows for standard ground shipping (use image to show how bumper goes together). Simple bolt-on installation using factory mounting locations and includes grade 8.8 zinc hardware. Heavy duty 1/4" and 3/16" steel plate construction for main center section. Heavy duty 12ga front cover plate center section provides protection and great styling of critical components. Accommodates 3.0" square lights (2 per side) under each headlight with integrated mounting points. (use image to point out). 98lb dry weight increases front end protection without drastically increasing weight. Durable black powder coating provides style and protection.
$1500 value
Selling for $850
Oceanside, CA
760-978-7100
Links of the items below for more information:
Off Camber Bumper:
LED Cube Lights:
Light Bar:
Bumper Install instructions:
https://store.mbrpautomotive.com/instructions/183199.pdf
00J0J_3y7sGR8k9om_1200x900.webp00t0t_lcOHrx6wu7s_1200x900.webp00w0w_1wCt8RTO97c_1200x900.webp
