Spindle Upgrade
  • Thread starter Thread starter zweisman
  • Replies Replies 3
  • Views Views 2K
zweisman
I've got the Camburg UCA's up front, and with all my preload, they're pretty much maxed out at normal ride height. Curious if anyone has gone and put on some longer spindles yet. The only ones I know of are the maxtrac 4" spindles, curious if anyone has gone this route to reduce the stress on their UCA's.
What coilovers and spring rate do you have? Any extra weight? Oem springs are 712 lb/in vs 2nd gen which are 540-590 lb/in. 600lb springs that come on allot of coilovers don't really cut it on 3rd gens without adding a ton of pre-load.
How are the UCAs maxed out?
Problem with longer spindles/knuckles is it doesn’t keep everything in line. You’ll have an elevated lca with a flat uca so as you cycle suspension the ball joint relation will be in a constant state of change. Unless you lower the lca to match the uca.
