Slidoomz 2019 Sr Access cab
slidoomz
5️⃣ Platinum
Suspension
King extended travel coilovers with 700LB spring
King Rear Shocks extended travel with Compression adjustment
Deaver Expeditions stage 2
Total Chaos Upper Control Arms
Timbrens Active Offroad Ubolt flip kit
Wheelers Offroad Superbump Front Bumptstop
BAMF HD shackle hanger with greasable replacement shackles
Wheels and Tires
Lt 315/75/17 BF-Goodrich K02
Konig Countersteer Type X made by fn wheels 17x8 offset -10(4.1 backspacing)
Exterior
Dobinsons Snorkel w/ Snorkel upgrade
Softopper
Sherpa Teton Roofrack
Armor
RCI Engine Skid
RCI Transmission skid
RCI Transfercase skid
True north fabrication hybrid bumper.(Winch)X-BULL Electric Winch 10000 LBS.
Bruteforce Fabrication high clearance rear bumper.
Custom Made 20 Degree sliders.
Performance
Harrop Eaton E-locker for Rear diff
Nitro Gears 5.29 gears
Valley tuned
Awaiting Install
Archive Garage Trail Series Rear Shock Relocation
King 2.0 12 inch smooth bodies.
Current
Before
Late to say it, but welcome to the forum. The stance on the truck looks good and your wheel choice is perfect. Did you get the 5100s installed?
Looks like we’re doing a lot of the same mods on similar trucks.
I have a couple questions for you.
1. Has the 5.29’s helped going slower and more controlled when rock crawling?
2. I’m going to the 650 pound Bilstein springs this week too. Bilstein recommends the access cab go no higher than 5/4 perch setting. Probably due to CV angles. Have you looked at your CV boots since you set yours on 6/5. Does the ribs on your CV boot touch?
Thanks in advance for your replies.
I recently purchased a bamf rear shock relocation kit. As of right now I’m saving up some shocks and the funds to get these installed.
New updates.. I picked up a new battery,bilstein 7100 14 inch shorty body 255/70 and found a sweet deal on this used set of stage 2 deaver expeditions. i have a rear bumper on order Bruteforce Fabrication high clearance rear bumper
i wish they were, they are actually Konig Countersteer Type X made by fn wheels. The shackle hangers are just a heavy duty replacement since the oem ones are just made out stamp steel and can bend if they hit a rock.
I installed the winch,I’m just waiting on a few parts to relocate the winch controller. I been messing around with the preload on the kings as well. It turns out it actually rides better with a lower preload 👍🏽.
